Hello, I was wondering if there was a way to get the name of a net attached to a pin and export it for autogenerating C definitions for processors. This would save a lot of time imo.
You mean just dump net name for each pin of a micro? That is easily doable with python in pcbnew.
As mentioned above, you could probably modify this code attached, that I did for reporting sets of net names attached to a named list of parts.
Main focus here was loom-checking, so connectors are in the example, but it can also be used for list extract from Processors, or CPLDs / FPGAs by enter of U1, etc
TablePinListReport.py (5.9 KB)
Ah that’s a better idea. I was trying to do it with eschema
