I want to export the layer stack for further processing. The only option I see is “Export to Clipboard” button, which gives me e.g.:
layer "F.Silkscreen" type "Top Silk Screen" Color "Not specified" Material "Not specified"
layer "F.Paste" type "Top Solder Paste"
layer "F.Mask" type "Top Solder Mask" Color "Not specified" Thickness 0.01 mm Material "Not specified" EpsilonR 3.3 LossTg 0
layer "F.Cu" type "copper" Thickness 0.035 mm
layer "Dielectric 1" type "core"
sublayer "1/3" Color "Not specified" Thickness 1.51 mm Material "FR4" EpsilonR 4.5 LossTg 0.02
sublayer "2/3" Thickness 0 mm Material "Not specified" EpsilonR 1 LossTg 0
sublayer "3/3" Thickness 0 mm Material "Not specified" EpsilonR 1 LossTg 0
layer "B.Cu" type "copper" Thickness 0.035 mm
layer "B.Mask" type "Bottom Solder Mask" Color "Not specified" Thickness 0.01 mm Material "Not specified" EpsilonR 3.3 LossTg 0
layer "B.Paste" type "Bottom Solder Paste"
layer "B.Silkscreen" type "Bottom Silk Screen" Color "Not specified" Material "Not specified"
Finish "None"
I want to create a simple CSV table with the layer stack, but going from this format into a table is cumbersome. The table I want to create is basically the same that is shown in the layer stack window:
Is there a script or something that does this? Is it possible to get this information in a more computer-friendly format like json or yaml? Or how would I get it from Python? Is the pcbnew package able to do this?
