In Kicad 6 is there any news regarding the export of the pcb to gcode?
I used a plugin for inkscape 0.9x but in version 1.1 it doesn’t work anymore and I don’t know how to export to gcode for laser engraving.
Best regards
Best regards
surely there are utilities that will convert Gerber files to gcode. That’s really outside of Kicad and more of a general-use tool.
Thank you.
I use pcb2gcode but the result is not very good to me.
Well, too bad.
G-code is manufacturing related and has nothing to do with KiCAD.
G-code should be generated from the Gerbers.
Been using this for 7 years and its a wonderful program (for my CNC Mill needs).
It has a ‘Laser’ checkbox in the tool panel (when setting up your tools).
It’s a Windows program but, I run it on my Mac using the ‘PlayOnMac’ Wine App… Just click the CopperCAM.exe and Bingo! I’ve used some other versions of Wine to run it but, now that I upgraded to Monterey, the only two Wine’s the run it are PlayOnMac (it’s free) and CodeWeaver’s version of Wine(not Free)…
EDIT: Bertrand (CopperCAM’s author) has tweaked/added features for me (by request). Good responses and timely… You can use it for Free unless needing to do large files…
EDIT2: I (just now) quickly made a Kicad Plugin to run CopperCAM/PlayOnMac. I don’t really need it - was just curious if a Wine/Windows app would run from Plugin. It Does!
Hi BlackCoffee,
Sound good but I never use Windows, only Gnu/Linux.
I use FlatCam, bCNC and CNCjs. bCNC and CNCjs are my favorites.
FlatCam not work with ubuntu >=20.04 and grbHAL. bCNC works fine.
In 2019 I was using Inkscape0.91 and work fine to engraving the kicad svg files, but in 1.1 not works Area in GcodePlot plugin. Now works fine to lines but I can not to fill. I’m find alternatives to this.
I’m going to try this pcb2gcode configuration in command line to see if I get it. Normally I have used the GUI to do it but then when importing in the Gcode sender it draws the travels and that is something undesirable because I have to be cleaning the gcode, something that does not happen with inkscape.
I have tried with this command and works fine but I have changed --dpi=1000 for --vectorial=true
I’ll keep testing, but the gcode looks much better.
Best regards
Another (open source) project for PCB milling:
Yes but in Ubuntu >20.04 fail. It’s necesary to use the Beta version that is hosting in Bitbucket.
I did a test with pcb2gcode and it’s amazing. I get better definition with my cheap laser than using my laser printer and UV exposure. This afternoon I will prepare some pcb to see if it works well.
Sounds like it’s almost solved.
FYI - here’s a link to ‘PlayOnLinux’ so you can run some Windows programs (including CopperCAM) on Linux…
