Hi!
I’m working on a 4-layer PCB in KiCad and have trouble with the export.
In the JLCPCB viewer, only the drill holes and a few traces are visible – most of the copper layers and routing don’t show up correctly.
Zones are filled, DRC is clean, and everything looks fine inside KiCad.
Since I’m a new user and can’t attach files directly here, I’ve uploaded the Kiicad pcb files via TransferNow:
Transfer "Kiicad" is available for download
I’d be super grateful if someone could take a look and tell me what’s wrong with the export.
Thanks in advance!
dsa-t
April 14, 2025, 6:13pm
2
The archive don’t seem to contain any exported files, only the project files.
Here is the transfernow link with the production files:
dsa-t
April 14, 2025, 6:48pm
4
btw, your power traces are too thin:
Also your 5V input seems to be connected only to U3 pin 111 (VBUS_EN), not to +5v.
Also you usually want to keep your high-speed signals clear of other signals and each other:
And there’s no ground return vias for high-speed signals.
You didn’t seem to follow any layout recommendations for DC-DC converters, it won’t work:
There’s resistors under J1, also how were you going to plug it in?
Does JLC support 0.125mm via holes?
dsa-t
April 14, 2025, 6:54pm
5
Don’t check any checkboxes in “Plot on all layers” when plotting. Every checked layer there is plotted on all layer.
Thank you for your feedback! It really helps a lot. I`m really new to this pcb stuff as you could see. What should I do right now in your own opinion?
You think I should redo everything and if could you help me then?
dsa-t
April 14, 2025, 7:06pm
8
Read datasheets and layout guides carefully. Read books, watch tutorials about routing high-speed signals, power integrity, signal integrity. Don’t use autorouters.
dsa-t
April 14, 2025, 7:17pm
9
It’s better to ask engineering questions on EEVblog Electronics Community Forum - Index instead of this KiCad forum.
You seem to be familiar with PCB designs. Can you help me create this PCB, or are you short on time?
I need help with redesigning this and you are the only person I can think off
