Exiting measure tool
Wasn’t sure where to post this, it’s not a feature request more a mild inconvenience.
In the PCB and Footprint editor, you can’t exit the measure tool with the Esc button. When selecting any other tool from the right hand tool menu you can exit the tool by hitting Esc, reverting to the cursor tool (Select item(s)).
In order to exit the measure tool you need to select a different tool, Esc does not work.
Version: 9.0.2, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) UHD Graphics 630, 4.6.0 - Build 30.0.101.1631
Date: May 7 2025 02:29:49
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
Hmm? Works for me in v8.0.9.
At this point ESC deletes the ruler and reverts the cursor to select mode.
Upgrade to 9.0.3. It may well be fixed in that version. See The PCB measuring tool cannot be turned off normally at certain times (#21016) · Issues · KiCad / KiCad Source Code / kicad · GitLab.
Thanks.
I did do a search, but obviously not in all the right places.
