I know on the schematic editor you can exclude the part from the PCB, but I want to only exclude the 2 pins (Pins 4 and 5)
What is the best way to do this? I"m thinking the only way is have two seperate footprints, one for the HV transformer (which I need to remove coil across 4-5) and then create a new footprint with the coil and set this to not appear on the PCB.
Is there a simpler way to do this I’m missing (On latest 6.99)
If you have a footprint in which some numbers are missing wouldn’t you just get an ERC warning that some symbol pins are not connected which you can then suppress or ignore? Ditto for one end of the diodes.
It must be late - why didn’t I think of that Yes, the not connected pins I’ll just suppress and make a note on the schematic that it’s connected to the heatsink.
