Exclude page from BOM
Hi guys
I’ve been searching the forum for an hour now and cannot seem to find a solution.
I have multi-page project which consists of 9 different pages and 3 PCBs. I’d like to create 3 separate BOMs for 3 PCBs as these will be handled differently.
Motherboard PCB is contained on 7 pages of schematic and 2 pages are separate PCBs.
All parts on all pages are prefixed with page numbers (eg. resistors on page 5 are all numbered R500, R501, R502… etc…)
Is there a way I can exclude a page while generating BOM? Did someone already generated a script with that functionality?
If not it seems that I might have to write it myself.
Any input is appreciated.
I managed to hack something quickly just by adding below 3 lines to bom_csv_grouped_by_value.py script in /usr/share/kicad/plugins
# Output all the interesting components individually first:
row = []
for c in components:
    # Added: do not add components from pages 5 and 7
    if re.match(r'^\D{1,3}[5|7]\d+', c.getRef()):
        print('Removed: ', c.getRef())
        continue
    del row[:]
    row.append('')                                      # item is blank in individual table
    row.append('')                                      # Qty is always 1, why print it
This script will print all skipped references:
"/usr/bin/python3" "/usr/share/kicad/plugins/bom_csv_group_by_value_exclude_pages.py" "/home/tdarlic/Documents/Kicad/projects/some_pcb/some_pcb.xml" "/home/tdarlic/Documents/Kicad/projects/some_pcb/some_pcb.csv"
Success.
Removed:  AN501
Removed:  C501
Removed:  C502
Removed:  C503
Removed:  C504
Removed:  C505
I might return to it later to get it more used friendly so one could choose which pages to include and which to skip.
OK
I’ve found even better place for placing regex for references that need to be excluded.
This is in kicad_netlist_reader.py file in /usr/share/kicad/plugins directory.
I needed to read trough comments to figure it out. There is a variable called excluded_references and I just added regex for all components that I wanted to skip.
# regular expressions which match component 'Reference' fields of components that
# are to be excluded from the BOM.
excluded_references = [
    'TP[0-9]+',            # all test points
    '^\D{1,3}[5,7]\d+',    # Pages 5 and 7
    '^FID.+',              # Fiducials
    '^JP\d+',              # Jumpers
    '^H\d+'                # Mounting holes
More advanced BOM generators like KiBom can recognize board variant field which will let you generate separate BOMs for your motherboard and daughterboards.
Thanks
I somehow missed KiBom. I’ll have a look at it.
