ESP32 Footprint DRC Warning
Hi, I am trying to finish my PCB design with ESP32-WROOM-32E-N8 I chosed the below footprint and I was doing DRC check. I got this footprint warning what could be the problem and what should I do ?
Have you tried comparing the footprint on your PCB with the one in the Library ?
Select the footprint, then . . .
I checked
In summary it says :
Rule Area on F.Cu and B.Cu layers differ.
In Visual I couldnt notice any difference
IF you are sure then you can update it from the Library and then there WILL be no differences :wink:
What does Rule are means ?
That’s a bug: Unavoidable DRC warning for footprints with copper layer rule area (#19694) · Issues · KiCad / KiCad Source Code / kicad · GitLab
You can ignore (exclude) the warning.
What version of KiCad are you using ?
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
