Error with pcb2dxf plugin
Hi, I am trying to run the pcb2dxf plugin under Windows 10. KiCad and the files are installed on a seperate HDD from C. D:\Programs\KiCad\7.0\bin\kicad.exe is the program location.
When I run the plugin I get the message window:
The plugins are in my directory “Documents” in C:\users\my.name. Could this be the source of the confusion and if it is, is there another palce I should keep the plugins?
There is no issue with the location of kicad or plugins. Your error is just a bug in the plugin, it’s not handling something on your pcb correctly. You should report it on the plugins github/gitlab page.
You are probably going to need to contact the Author of the Plugin for help.
Here maybe: Issues · easyw/kicad-action-tools · GitHub
Thanks for the swift response. I will do as suggested.
pcb2dxf is getting obsolete by the internal kicad plot ability…
I think I should remove it from action tools…
Looks like a known issue: Export to DXF error · Issue #8 · easyw/kicad-action-tools · GitHub
