I save hierarchical sheet with subcircuit I will reuse later outside the project I’m working on.
After that I got 3 warning popup saying some things about the component table, but, I can go through the sheet and got my hierarchical pin
When I try to reopen the sch root file, I got an error message saying the hierarchical sheet file is already open.
The error :
La schématique n’a pas pu être complètement chargée. Des erreurs se sont produites lors du chargement des feuilles hiérarchiques. Ne peut pas ouvrir le fichier /Users/louis/Documents/Code/Modular-Project/docs/modules/Hagiwo/2_OP_FM/hardware/pcb/${DOD_LIBRARIES}/Subcircuits/5V_adc_input.kicad_sch en lecture.
I’m on MacOS Ventura, Kicad 7.0.7
I tried to reboot the computer for a fresh import with all applications closed, apart Kicad.
Do u have the same worflow ?
