Some can help me with the ERC Error type 3 in my schematic in the dual op amp pin 4.
Its saying there is nothing driving your ground net, but some device, likely the op amp has its V- pin set as a power input, as such create a power flag and tie it to ground. that will fix it.
Thanks , it’s done. fix it.
Make sure you put the power flag where your pcb is supplied. Otherwise ERC is useless with regard to detecting if your stuff is supplied.
