I tried JLCPCB Fabrication ToolKit plugin but this following error statement was output.
ERROR : in method ‘BOARD_DESIGN_SETTINGS_m_SolderMaskMargin_set’, argument 2 of type ‘int’.
What should I do?
What should I do?
I myself use this one. I don’t know if we are talking about the same one or not. If not you can try switching to this plugin instead?
It works really well and gives me good gerbers, BOM and CPL with a single mouseclick.
Regards,
Bas
Thank you for your good information.
I tried using this and could generate gerber files easily.
But I want to use official plugin by JLCPCB so I will continue to ask question about above error.
Have you tried asking here ? :
(taken from the Plugin details in the KiCad Plugin and Content Manager)
And have you checked the Issues on the Github page, in particular this one? Error in PCB editor when clicking fabrication · Issue #81 · bennymeg/JLC-Plugin-for-KiCad · GitHub
And from that issue it sounds like you might be using KiCad v6 but you didn’t tell us your KiCad version.
