Hello, I am facing this issue in schematic, can anyone help me out.
Error: Input Power pin not driven by any Output power pins
Symbol U8 Pin 5 [GND2, Power input, line].
I get that one all the time.
Itâs pretty harmless and should not prevent you from using the circuit otherwise.
The solution is to add a âpower flagâ (PWR_FLAG) to your supply voltages. Itâs found in the âpowerâ library.
IMO, it should be downgraded to a âWarningâ.
Is pin 5 U8 properly connected to the wire?
Is there a small green square at the end of the wire joining pin 5?
It is too hard to see on your image.
It looks like you used some sort of camera (maybe your phone) to take a photo of your display monitor. Canât you use an image grabbing utility, such as Windows snipping tool?
Looks OK I think . . .
If it is not an off grid (non)connection, it must be no power flag on Gnd or wrong electrical type on pin 5.
A bit hard to tell without the whole (and clear) schematic.
above is the link to access the PDF of my schematic, as a new user i unable to upload here.
You are now a âbasic userâ and can upload things here. Welcome to the forum.
