Error in reading netlist
HI,
When i trying to read the current netlist they shows some errors. they are as follows
Error: Component ‘U2’ pad ‘~’ not found in footprint ‘TDFN-10:TDFN-10’
i also tried to change the particular footprint but again it also shows the same error.can anyone suggest a methode to avoid these errors.
Each symbol pin of the schematic has a pin number that must match with a pad number in the footprint.
In your case, it seems you have a pin in U2 with pin number ~ while the footprint TDFN-10:TDFN-10 has no pad with that number
hai pedro,
can u suggest any methode to avoid these errors.
Just added a topic to the FAQ. (click the link or press the arrow to see the full post)
thank you@ Rene_Poschi
There is only one way: edit the symbol and re-number the pins with conflict.
Follow the FAQ entry suggested by Rene Poschl.
