Hi Folks,
I’ve got a .kicad_pcb file that was generated by pcbnew “(5.1.2)-2”. It loads ok into KiCad 7 PCB Editor, but fails to load into KiCad 8 PCB Editor, giving the following error message:
Error loading PCB ‘SOIC28.kicad_pcb’. Expecting ‘font, justify, or hide’ in ‘SOIC28.kicad_pcb’ line 1094, offset 6.
Just before line 1094, is the following text:
(dimension 33.02 (width 0.15) (layer Dwgs.User)
(gr_text "33.020 mm" (at 66.675 26.259) (layer Dwgs.User)
(effects (font (size 1 1) (thickness 0.15)) hide)
If I manually remove the ‘hide’ parameter from this dimension field (and the other dimension fields) it loads ok. Is this a bug in the latest KiCad 8.0.1 release, or am I doing something wrong with the import?
I did try to look on gitlab for an existing bug report, but struggled to find anything. I also struggled to find a changelog for any of the nightlies, so if it is a bug perhaps it has already been fixed?
