When I open the Footprint Wizard, I select row 5 BGA. Afterwards, I get a alert window with some cryptic debugging output. When I dismiss the alert window, there is no generated footprint. Also, if I modify pitch, size, columns or rows parameters the alert window appears again.
If I choose another option, like the wizard for SOIC, then Kicad appears to run normally without an error message.
Any suggested would help. I’m running on Ubuntu.
Linux clyde 5.8.0-7625-generic #26~1603389471~20.04~f6b125f~dev-Ubuntu SMP Thu Oct 22 20:29:31 x86_64 x86_64 x86_64 GNU/Linux
Here is a screenshot of the alert window: something about an object type error in a python script called bga_wizard.py line 87 and PadArray.py line 215.
Version Info:
Application: ModEdit
Version: 5.1.7-a382d34a8~87~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.8.0-7625-generic x86_64, 64 bit, Little endian, wxGTK
Boost: 1.71.0
Curl: 7.68.0
Compiler: GCC 9.3.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
