Error exporting schematic to PCB
I am not getting those error when I am running DRC. I have converter the schematic to PCB , all the resistors and capacitors dont have nets associated with them. Can you please let me know the reason and what can be done.
Can you post a picture of the schematic?
Hi ,
Thankyou so much for helping me out. I am posting the schematic here.
It looks like there are a lot of pins that are not properly connected. All the ones with squares on them are not connected. Check your grid size and make sure the wires line up with the pins otherwise they will not be conneted.
I will look into it. however I am not getting error while running ERC for the schematic.
In the schematic, can you use the highlight net tool and confirm the schematic shows the net as expected. Do a screenshot of one small net so we can see better detail.
Otherwise you might use the archive function to zip the project and post it here.
Could those 88 warnings be about not connected pins ? The box is not checked.
Hi Hermit,
I could resolve the resistor and capacitor issues. The components didn’t have pinnumber visible in the symbol section. I am currently having similar issue with the diode. I am attaching the screenshot here. Please do see if you can help me with this. Here the diodes net are not exporting to the schematic. I have numbererd the pins properly this time.
I have checked that but nothing useful . Please see the below issue , If you can help me solve this
We can not help much from some screenshots. To be able to examine what is going on we need the whole project, or better: just a small part of the project that shows the problem.
You can:
  1. Make a copy of your project.
  2. Delete most of the schematic, just leave a few parts that show your problem.
  3. Verify the problem is still in that modified project.
  4. Zip it up and post the simplified project here. (You can just drag it from a file browser to the edit window).
  1. No footprint defined for diode? What does “import changes from schematic” log say?
  2. Also, maybe diode is set as "no board’ component? See the checkboxes in the lower part of “symbol properties” dialog in the schematic.
