Error: BT2 footprint 'BAT_BAT-HLD-001' not found in any libraries in the footprint library table. Error: Cannot add BT2 (footprint 'BAT-HLD-001:BAT_BAT-HLD-001' not found)
I get this error when trying to transfer my schematic to a pcb with my netlist file. Error: BT2 footprint ‘BAT_BAT-HLD-001’ not found in any libraries in the footprint library table.
Error: Cannot add BT2 (footprint ‘BAT-HLD-001:BAT_BAT-HLD-001’ not found). I added a footprint to solve this error, it gave the same error again, I added it as a library, it still gives the same error, I kindly ask for your help, thank you.
Welcome to the KiCad forum, try using the footprint library browser to see what is inside of those libraries that you added, it may be a simple misspelling or not existing at all.
Hello, thank you for your answer. When I check from the library, the footprints appear to have been created, but the error persists.
I think you may be crossing the footprint name and Library name . . . the error message is about a footprint called: BAT_BAT-HLD-001, then you seem to have created a footprint called: BAT-HLD-001
which won’t fix the original issue.
