Erreur pin puissance
Bonjour,
j’ai fait un schéma hyper simple juste une led et une résistance, +12v et GND. Lors du test électrique, j’ai le message “pin entrée de puissance pilotée par aucune pin sortie de puissance” avec une flèche au niveau du +12v et de GND. que faire ? merci.
https://docs.kicad.org/9.0/fr/eeschema/eeschema.html#power-pins-and-power-flags
Unfortunately this part of the document has not been translated yet.
Attache symbols “PWR_FLAG” a chaque signal.
[EDIT] Il fault utiliser Google translate dans cet forum.
"Attache symbols “PWR_FLAG” a chaque signal.
[EDIT] Il fault utiliser Google translate dans cet forum."
Very poor translation …
Please do not just criticise a translation. Improve the translation if you are able.
This forum is about communication with those asking for help :slightly_smiling_face:
What I meant is if this is Google translation, this is very poor translation and Google Translate should not be used.
“Il faut attacher un symbol ‘PWR_FLAG’ à chaque signal.
Il faut utiliser ‘Google Translate’ dans ce forum”
Google (if it is) may be the best translation available to the member trying to offer help.
If you are able to improve the translation, please do.
May I suggest to not translate and let the user translate on his own ?
Maybe the user is not bilingual and would need to use such as Google for translation. We still have very poor communication.
I’ll write it again: If you are able to improve the translation, please do.
I made a super simple diagram with just an LED and a resistor, +12V, and GND. During the electrical test, I got the message “power input pin controlled by no power output pin” with an arrow at +12V and GND. What should I do? Thanks.
Thankyou @Michel_Dagenais :+1: :+1: :+1: :grinning:
Now all members who understand English are able to reply.
My French is not better. But thanks for the friendly feedback…
