What happen to V7.0.2 ERC?
There is no error in V7.0.1 if I test it using ERC
How this error comes? Is this a bug or as designed?
Nothing error if I test it using V 7.0.1
Were you able to solve it? I have run into the same issue:
Anyway, for the time being I simply clicked on “ignore all SPICE simulation related errors”
Yes, that’s simple solution.
But is the error set by default?
So we need to ignore it?
Yes; it’s a bug that will be fixed in 7.0.3 and you need to just ignore that error for now (or disable it in settings)
Maybe? But just as in your case, I did not have this issue with the previous version. Maybe they changed something in the newer version.
Ah, I see. Well, thanks for clarifying.
A bug reference: ERC: Failed to read simulation model from fields (#14562) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Here are the steps to disable simulation errors in KiCad 7.0.2
Hi Mr. Jon Evans, when KiCad V7.0.3 will be released?
Thanks to KiCad developers
Hi @sarfat96
There will not be a 7.0.3. Please scroll to the bottom of this thread for an explanation.
I just got the same error:
I reverted to version 7.0.1 and I prefer to wait for the next updated version.
Regards
Salvatore
I have this same error running inside a Fedora rawhide official docker image (fedora:rawhide) (Inspect → Simulator → Simulation → Show SPICE Netlist). The error happens with Any BJT transistor, and the option to ignore SPICE errors is Already Marked.
Version Info:
Version: 7.0.5-1.fc39, release build
wxWidgets 3.2.2
FreeType 2.13.0
HarfBuzz 7.3.0
FontConfig 2.14.2
libcurl/8.1.2 OpenSSL/3.0.8 zlib/1.2.13 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.2 (+libidn2/2.3.4) libssh/0.10.5/openssl/zlib nghttp2/1.53.0
Platform: Fedora release 39 (Rawhide), 64 bit, Little endian, wxGTK, , x11
Date: May 26 2023 00:00:00
wxWidgets: 3.2.2 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.81.0
OCC: 7.6.3
Curl: 8.1.1
ngspice: 40
Compiler: GCC 13.1.1 with C++ ABI 1018
KICAD_SPICE=ON
Anyways, it don’t make sense to disable SPICE simulation if what you want is exactly that: TO simulate. Please stop asking people to do this.
