Empty Property Name error while opening schematic in Kicad
Hey there, I am using Kicad 7.0.2. I am not able to open my schematic file in Kicad, it show error like: “Empty property name in “file path” in line 20XX, offset 16.”
Whenever I make a new schematic, it runs for the first time, but when i try to launch it after closing it, this error occurs. I tried opening the file in text editor and the property fields are empty. I have no idea what to put it in there. Anyone have any solutions for it?
Can you post the version info. Help / About KiCad
Are you able to zip the project and attach here (If it’s not confidential)
Guessing here, but can you try a folder without a space in it (I can’t imagine that the issue but worth ruling out)
Here is the version info :
Application: KiCad x64 on x64
Version: 7.0.2, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Apr 15 2023 19:18:27
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.6.3
Curl: 7.88.1-DEV
ngspice: 40
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
Here is the link for zip of the folder… what do you think the issue can be?
I’m getting the same issue on 7.0.2 in Ubuntu.
The issue is being caused by this field in the .kicad_sch file (Actually a number of components with the problem)
    (property "" "COM-09426" (at 228.6 74.295 0)
      (effects (font (size 1.524 1.524)) (justify left))
The property value is empty causing the crash. Might be worth raising a bug for this.
As a workaround you can edit the file with a text editor (make a backup first) and remove the 3 lines. (I’m not sure what the property should even be) You will have to search through the file as the empty property appears a number of times.
Are these parts coming from a legacy .lib library? Try migrating the library to the new .kicad_sym format in the library manager. That did the trick for me.
Hello All, I am also having the same issue.
I ended up opening my .kicad_sch file in Vim and I found the property as shown above. After looking around before and after this code it seemed to be a component instance and the property which was causing an issue was an unnamed field in the Symbol properties. I edited it to reflect the right Field title and the problem went away. The project opens with no problem.
I guess the issue has to do with legacy vs. 7.0 KiCAD. Legacy seems to have dealt with unnamed symbol property fields better than 7.0.
I tried this but the issue was still there. Maybe it would have worked if I was also able to update the SCH with the newly migrated components. I think lesson learned is migrate your .lib’s first then include newly migrated components into the new KiCAD schematic.
Oh, yeah. You’ll need to manually delete the old part from the schematic using a text editor. Then add it back in after migrating the library.
Actually, I didn’t manually delete the part using the text editor, I used the text editor to fill in the missing property field name.
I.e.
changed to:
   (property "Manufacturer PN" "COM-09426" (at 228.6 74.295 0)
