Empty clear list of default hotkey
How to clean the entire list of default hotkey?
I want to setup only the hotkeys I need and use
There is no builtin-function to clear all assigned hotkey combinations to get a empty hotkey list.
Maybe it works if you manually modify the file “user.hotkeys” in your kicad settings folder.
I did open the kicad default “user.hotkeys” file in text editor then removed every text after the tabs. It ended up like this (see text under dots below):
Why not copy this text (after dots below) and paste the text in to your text editor then save a file with name “user.hotkeys” (no extension) and replace the KiCad default file. Note I can not guarantee this will work, do it on own risk. In my system it worked.
3DViewer.Control
3DViewer.Control.attribute_dnp
3DViewer.Control.attribute_not_in_posfile
3DViewer.Control.attributesOther
3DViewer.Control.attributesSMD
3DViewer.Control.attributesTHT
3DViewer.Control.flipView
3DViewer.Control.homeView
3DViewer.Control.materialCAD
3DViewer.Control.materialDiffuse
3DViewer.Control.materialNormal
3DViewer.Control.moveDown
3DViewer.Control.moveLeft
3DViewer.Control.moveRight
3DViewer.Control.moveUp
3DViewer.Control.noGrid
3DViewer.Control.pivotCenter
3DViewer.Control.resetView
3DViewer.Control.rotateXclockwise
3DViewer.Control.rotateXcounterclockwise
3DViewer.Control.rotateYclockwise
3DViewer.Control.rotateYcounterclockwise
3DViewer.Control.rotateZclockwise
3DViewer.Control.rotateZcounterclockwise
3DViewer.Control.show10mmGrid
3DViewer.Control.show1mmGrid
3DViewer.Control.show2_5mmGrid
3DViewer.Control.show5mmGrid
3DViewer.Control.showAxis
3DViewer.Control.showBoundingBoxes
3DViewer.Control.showLayersManager
3DViewer.Control.toggleAdhesive
3DViewer.Control.toggleBoardBody
3DViewer.Control.toggleComments
3DViewer.Control.toggleECO
3DViewer.Control.toggleOrtho
3DViewer.Control.toggleRealisticMode
3DViewer.Control.toggleSilk
3DViewer.Control.toggleSolderMask
3DViewer.Control.toggleSolderPaste
3DViewer.Control.toggleZones
3DViewer.Control.viewBack
3DViewer.Control.viewBottom
3DViewer.Control.viewFront
3DViewer.Control.viewLeft
3DViewer.Control.viewRight
3DViewer.Control.viewTop
common.API.pluginsReload
common.Checker.excludeMarker
common.Checker.nextMarker
common.Checker.prevMarker
common.Control.activatePointEditor
common.Control.addLibrary
common.Control.centerContents
common.Control.centerJustify
common.Control.centerSelection
common.Control.collapseAll
common.Control.cursorClick
common.Control.cursorDblClick
common.Control.cursorDown
common.Control.cursorDownFast
common.Control.cursorLeft
common.Control.cursorLeftFast
common.Control.cursorRight
common.Control.cursorRightFast
common.Control.cursorUp
common.Control.cursorUpFast
common.Control.ddaddLibrary
common.Control.editGridOrigin
common.Control.editGrids
common.Control.expandAll
common.Control.gridFast1
common.Control.gridFast2
common.Control.gridFastCycle
common.Control.gridNext
common.Control.gridPreset
common.Control.gridPrev
common.Control.gridProperties
common.Control.gridResetOrigin
common.Control.gridSetOrigin
common.Control.hideLibraryTree
common.Control.highContrastMode
common.Control.highContrastModeCycle
common.Control.imperialUnits
common.Control.leftJustify
common.Control.libraryTreeSearch
common.Control.magneticSnapActiveLayer
common.Control.magneticSnapAllLayers
common.Control.magneticSnapToggle
common.Control.metricUnits
common.Control.mils
common.Control.new
common.Control.newLibrary
common.Control.open
common.Control.openDirectory
common.Control.openWithTextEditor
common.Control.pageSettings
common.Control.panDown
common.Control.panLeft
common.Control.panRight
common.Control.panUp
common.Control.pinLibrary
common.Control.plot
common.Control.print
common.Control.quit
common.Control.redoZoom
common.Control.refreshPreview
common.Control.resetLocalCoords
common.Control.revert
common.Control.rightJustify
common.Control.save
common.Control.saveAll
common.Control.saveAs
common.Control.saveCopy
common.Control.selectColumns
common.Control.show3DViewer
common.Control.showContextMenu
common.Control.showDatasheet
common.Control.showFootprintBrowser
common.Control.showFootprintEditor
common.Control.showLibraryTree
common.Control.showProjectManager
common.Control.showProperties
common.Control.showSymbolBrowser
common.Control.showSymbolEditor
common.Control.toggleBoundingBoxes
common.Control.toggleCursor
common.Control.toggleCursorStyle
common.Control.toggleGrid
common.Control.toggleGridOverrides
common.Control.togglePolarCoords
common.Control.toggleUnits
common.Control.undoZoom
common.Control.unpinLibrary
common.Control.updateFind
common.Control.updatePcbFromSchematic
common.Control.updatePreferences
common.Control.updateSchematicFromPCB
common.Control.updateUnits
common.Control.zoomCenter
common.Control.zoomFitObjects
common.Control.zoomFitScreen
common.Control.zoomFitSelection
common.Control.zoomIn
common.Control.zoomInCenter
common.Control.zoomInHorizontally
common.Control.zoomInVertically
common.Control.zoomOut
common.Control.zoomOutCenter
common.Control.zoomOutHorizontally
common.Control.zoomOutVertically
common.Control.zoomPreset
common.Control.zoomRedraw
common.Control.zoomTool
common.Embed.embededFile
common.Embed.extractFile
common.Embed.removeFile
common.Interactive.cancel
common.Interactive.copy
common.Interactive.copyAsText
common.Interactive.cut
common.Interactive.cycleArcEditMode
common.Interactive.delete
common.Interactive.deleteTool
common.Interactive.duplicate
common.Interactive.find
common.Interactive.findAndReplace
common.Interactive.findNext
common.Interactive.findNextMarker
common.Interactive.findPrevious
common.Interactive.finish
common.Interactive.measureTool
common.Interactive.paste
common.Interactive.pasteSpecial
common.Interactive.redo
common.Interactive.replaceAll
common.Interactive.replaceAndFindNext
common.Interactive.search
common.Interactive.selectAll
common.Interactive.undo
common.Interactive.unselectAll
common.Interactive.updateMenu
common.InteractiveEdit.measureTool
common.InteractivePicker.pickerSubTool
common.InteractivePicker.pickerTool
common.InteractiveSelection.Rows
common.InteractiveSelection.SelectColumns
common.InteractiveSelection.SelectTable
common.InteractiveSelection.selectionTool
common.SuiteControl.about
common.SuiteControl.configurePaths
common.SuiteControl.donate
common.SuiteControl.getInvolved
common.SuiteControl.gettingStarted
common.SuiteControl.help
common.SuiteControl.listHotKeys
common.SuiteControl.openPreferences
common.SuiteControl.reportBug
common.SuiteControl.showDesignBLockLibTable
common.SuiteControl.showFootprintLibTable
common.SuiteControl.showSymbolLibTable
common.TableEditor.addColAfter
common.TableEditor.addColBefore
common.TableEditor.addRowAbove
common.TableEditor.addRowBelow
common.TableEditor.deleteColumns
common.TableEditor.deleteRows
common.TableEditor.mergeCells
common.TableEditor.unmergeCell
eeschema.AlignToGrid
eeschema.EditorControl.annotate
eeschema.EditorControl.annotateAutomatically
eeschema.EditorControl.assignFootprints
eeschema.EditorControl.clearHighlight
eeschema.EditorControl.ddAppendFile
eeschema.EditorControl.drawSheetOnClipboard
eeschema.EditorControl.editLibSymbolWithSymbolEditor
eeschema.EditorControl.editPageNumber
eeschema.EditorControl.editSymbolFields
eeschema.EditorControl.editSymbolLibraryLinks
eeschema.EditorControl.editWithSymbolEditor
eeschema.EditorControl.exportNetlist
eeschema.EditorControl.exportSymbolsToLibrary
eeschema.EditorControl.exportSymbolsToNewLibrary
eeschema.EditorControl.generateBOM
eeschema.EditorControl.generateBOMExternal
eeschema.EditorControl.generateBOMLegacy
eeschema.EditorControl.highlightNet
eeschema.EditorControl.highlightNetTool
eeschema.EditorControl.importFPAssignments
eeschema.EditorControl.importGraphics
eeschema.EditorControl.incrementAnnotations
eeschema.EditorControl.lineMode45
eeschema.EditorControl.lineModeFree
eeschema.EditorControl.lineModeNext
eeschema.EditorControl.lineModeOrthonal
eeschema.EditorControl.markSimExclusions
eeschema.EditorControl.nextUnit
eeschema.EditorControl.previousUnit
eeschema.EditorControl.remapSymbols
eeschema.EditorControl.repairSchematic
eeschema.EditorControl.rescueSymbols
eeschema.EditorControl.restartMove
eeschema.EditorControl.runSimulation
eeschema.EditorControl.saveCurrSheetCopyAs
eeschema.EditorControl.schematicSetup
eeschema.EditorControl.selectOnPCB
eeschema.EditorControl.setDNP
eeschema.EditorControl.setExcludeFromBOM
eeschema.EditorControl.setExcludeFromBoard
eeschema.EditorControl.setExcludeFromSimulation
eeschema.EditorControl.showDirectiveLabels
eeschema.EditorControl.showERCErrors
eeschema.EditorControl.showERCExclusions
eeschema.EditorControl.showERCWarnings
eeschema.EditorControl.showHiddenFields
eeschema.EditorControl.showHiddenPins
eeschema.EditorControl.showNetNavigator
eeschema.EditorControl.showOperatingPointCurrents
eeschema.EditorControl.showOperatingPointVoltages
eeschema.EditorControl.showPcbNew
eeschema.EditorControl.showPythonConsole
eeschema.EditorControl.showSimulator
eeschema.EditorControl.toggleDNP
eeschema.EditorControl.toggleExcludeFromBOM
eeschema.EditorControl.toggleExcludeFromBoard
eeschema.EditorControl.toggleExcludeFromSimulation
eeschema.EditorControl.togglePinAltIcons
eeschema.EditorControl.unsetDNP
eeschema.EditorControl.unsetExcludeFromBOM
eeschema.EditorControl.unsetExcludeFromBoard
eeschema.EditorControl.unsetExcludeFromSimulation
eeschema.EditorControl.updateNetHighlighting
eeschema.EditorTool.showHierarchy
eeschema.InspectionTool.checkSymbol
eeschema.InspectionTool.diffSymbol
eeschema.InspectionTool.runERC
eeschema.InspectionTool.showBusSyntaxHelp
eeschema.InspectionTool.showDatasheet
eeschema.Interactive.decrementPrimary
eeschema.Interactive.decrementSecondary
eeschema.Interactive.increment
eeschema.Interactive.incrementPrimary
eeschema.Interactive.incrementSecondary
eeschema.InteractiveDrawing.closeOutline
eeschema.InteractiveDrawing.deleteLastPoint
eeschema.InteractiveDrawing.drawArc
eeschema.InteractiveDrawing.drawBezier
eeschema.InteractiveDrawing.drawCircle
eeschema.InteractiveDrawing.drawRectangle
eeschema.InteractiveDrawing.drawRuleArea
eeschema.InteractiveDrawing.drawSheet
eeschema.InteractiveDrawing.drawSheetFromDesignBlock
eeschema.InteractiveDrawing.drawSheetFromFile
eeschema.InteractiveDrawing.drawTable
eeschema.InteractiveDrawing.drawTextBox
eeschema.InteractiveDrawing.finishSheet
eeschema.InteractiveDrawing.importSheet
eeschema.InteractiveDrawing.importSheetPin
eeschema.InteractiveDrawing.placeBusWireEntry
eeschema.InteractiveDrawing.placeClassLabel
eeschema.InteractiveDrawing.placeDesignBlock
eeschema.InteractiveDrawing.placeGlobalLabel
eeschema.InteractiveDrawing.placeHierarchicalLabel
eeschema.InteractiveDrawing.placeImage
eeschema.InteractiveDrawing.placeJunction
eeschema.InteractiveDrawing.placeLabel
eeschema.InteractiveDrawing.placeNextSymbolUnit
eeschema.InteractiveDrawing.placeNoConnect
eeschema.InteractiveDrawing.placePowerSymbol
eeschema.InteractiveDrawing.placeSchematicText
eeschema.InteractiveDrawing.placeSheetPin
eeschema.InteractiveDrawing.placeSymbol
eeschema.InteractiveDrawing.syncAllSheetsPins
eeschema.InteractiveDrawing.syncSheetPins
eeschema.InteractiveDrawingLineWireBus.drawBuses
eeschema.InteractiveDrawingLineWireBus.drawLines
eeschema.InteractiveDrawingLineWireBus.drawWires
eeschema.InteractiveDrawingLineWireBus.finish
eeschema.InteractiveDrawingLineWireBus.finishBus
eeschema.InteractiveDrawingLineWireBus.finishLine
eeschema.InteractiveDrawingLineWireBus.finishWire
eeschema.InteractiveDrawingLineWireBus.switchPosture
eeschema.InteractiveDrawingLineWireBus.undoLastSegment
eeschema.InteractiveDrawingLineWireBus.unfoldBus
eeschema.InteractiveEdit.assignNetclass
eeschema.InteractiveEdit.autoplaceFields
eeschema.InteractiveEdit.breakWire
eeschema.InteractiveEdit.changeSymbol
eeschema.InteractiveEdit.changeSymbols
eeschema.InteractiveEdit.cleanupSheetPins
eeschema.InteractiveEdit.editFootprint
eeschema.InteractiveEdit.editReference
eeschema.InteractiveEdit.editTextAndGraphics
eeschema.InteractiveEdit.editValue
eeschema.InteractiveEdit.mirrorH
eeschema.InteractiveEdit.mirrorV
eeschema.InteractiveEdit.pinTable
eeschema.InteractiveEdit.properties
eeschema.InteractiveEdit.repeatDrawItem
eeschema.InteractiveEdit.rotateCCW
eeschema.InteractiveEdit.rotateCW
eeschema.InteractiveEdit.showDeMorganAlternate
eeschema.InteractiveEdit.showDeMorganStandard
eeschema.InteractiveEdit.slice
eeschema.InteractiveEdit.swap
eeschema.InteractiveEdit.symbolProperties
eeschema.InteractiveEdit.toCLabel
eeschema.InteractiveEdit.toGLabel
eeschema.InteractiveEdit.toHLabel
eeschema.InteractiveEdit.toLabel
eeschema.InteractiveEdit.toText
eeschema.InteractiveEdit.toTextBox
eeschema.InteractiveEdit.toggleDeMorgan
eeschema.InteractiveEdit.updateSymbol
eeschema.InteractiveEdit.updateSymbols
eeschema.InteractiveMove
eeschema.InteractiveMove.drag
eeschema.InteractiveMove.move
eeschema.InteractiveSelection
eeschema.InteractiveSelection.AddItemToSel
eeschema.InteractiveSelection.AddItemsToSel
eeschema.InteractiveSelection.ClearSelection
eeschema.InteractiveSelection.RemoveItemFromSel
eeschema.InteractiveSelection.RemoveItemsFromSel
eeschema.InteractiveSelection.SelectConnection
eeschema.InteractiveSelection.SelectNode
eeschema.InteractiveSelection.SelectionMenu
eeschema.InteractiveSelection.SyncSelection
eeschema.NavigateTool.back
eeschema.NavigateTool.changeSheet
eeschema.NavigateTool.enterSheet
eeschema.NavigateTool.forward
eeschema.NavigateTool.leaveSheet
eeschema.NavigateTool.next
eeschema.NavigateTool.previous
eeschema.NavigateTool.up
eeschema.PinEditing.pushPinLength
eeschema.PinEditing.pushPinNameSize
eeschema.PinEditing.pushPinNumSize
eeschema.PointEditor.addCorner
eeschema.PointEditor.removeCorner
eeschema.SchDesignBlockControl.editDesignBlockProperties
eeschema.SchDesignBlockControl.saveDeleteDesignBlock
eeschema.SchDesignBlockControl.saveSelectionAsDesignBlock
eeschema.SchDesignBlockControl.saveSheetAsDesignBlock
eeschema.SchDesignBlockControl.showDesignBlockPanel
eeschema.Simulation.editUserDefinedSignals
eeschema.Simulation.newAnalysisTab
eeschema.Simulation.openWorkbook
eeschema.Simulation.probe
eeschema.Simulation.runSimulation
eeschema.Simulation.saveWorkbook
eeschema.Simulation.saveWorkbookAs
eeschema.Simulation.showNetlist
eeschema.Simulation.simAnalysisProperties
eeschema.Simulation.stopSimulation
eeschema.Simulation.tune
eeschema.Simulator.exportCSV
eeschema.Simulator.exportPNG
eeschema.Simulator.exportPlotToSchematic
eeschema.Simulator.exportToClipboard
eeschema.Simulator.toggleDarkModePlots
eeschema.Simulator.toggleDottedSecondary
eeschema.Simulator.toggleLegend
eeschema.SymbolDrawing.drawSymbolLines
eeschema.SymbolDrawing.drawSymbolPolygon
eeschema.SymbolDrawing.drawSymbolTextBox
eeschema.SymbolDrawing.finishDrawing
eeschema.SymbolDrawing.placeSymbolAnchor
eeschema.SymbolDrawing.placeSymbolPin
eeschema.SymbolDrawing.placeSymbolText
eeschema.SymbolLibraryControl.addSymbolToSchematic
eeschema.SymbolLibraryControl.copySymbol
eeschema.SymbolLibraryControl.cutSymbol
eeschema.SymbolLibraryControl.deleteSymbol
eeschema.SymbolLibraryControl.deriveFromExistingSymbol
eeschema.SymbolLibraryControl.duplicateSymbol
eeschema.SymbolLibraryControl.editSymbol
eeschema.SymbolLibraryControl.exportSymbol
eeschema.SymbolLibraryControl.exportSymbolAsSVG
eeschema.SymbolLibraryControl.exportSymbolView
eeschema.SymbolLibraryControl.hideSymbolTree
eeschema.SymbolLibraryControl.importSymbol
eeschema.SymbolLibraryControl.newSymbol
eeschema.SymbolLibraryControl.openWithTextEditor
eeschema.SymbolLibraryControl.pasteSymbol
eeschema.SymbolLibraryControl.renameFootprint
eeschema.SymbolLibraryControl.saveLibraryAs
eeschema.SymbolLibraryControl.saveSymbolAs
eeschema.SymbolLibraryControl.saveSymbolCopyAs
eeschema.SymbolLibraryControl.setUnitDisplayName
eeschema.SymbolLibraryControl.showElectricalTypes
eeschema.SymbolLibraryControl.showHiddenFields
eeschema.SymbolLibraryControl.showHiddenLibFields
eeschema.SymbolLibraryControl.showHiddenLibPins
eeschema.SymbolLibraryControl.showHiddenPins
eeschema.SymbolLibraryControl.showPinNumbers
eeschema.SymbolLibraryControl.showSymbolTree
eeschema.SymbolLibraryControl.toggleSyncedPinsMode
eeschema.SymbolLibraryControl.updateSymbolFields
eeschema.SymbolMoveTool
gerbview.Control.clearAllLayers
gerbview.Control.clearLayer
gerbview.Control.dcodeDisplay
gerbview.Control.exportToPcbnew
gerbview.Control.flashedDisplayOutlines
gerbview.Control.flipGerberView
gerbview.Control.highlightAttribute
gerbview.Control.highlightClear
gerbview.Control.highlightComponent
gerbview.Control.highlightDCode
gerbview.Control.highlightNet
gerbview.Control.layerChanged
gerbview.Control.layerNext
gerbview.Control.layerPrev
gerbview.Control.linesDisplayOutlines
gerbview.Control.loadGerbFiles
gerbview.Control.loadZipFile
gerbview.Control.moveLayerDown
gerbview.Control.moveLayerUp
gerbview.Control.negativeObjectDisplay
gerbview.Control.openAutodetected
gerbview.Control.openDrillFile
gerbview.Control.openGerber
gerbview.Control.openJobFile
gerbview.Control.openZipFile
gerbview.Control.polygonsDisplayOutlines
gerbview.Control.reloadAllLayers
gerbview.Control.toggleDiffMode
gerbview.Control.toggleForceOpacityMode
gerbview.Control.toggleLayerManager
gerbview.Control.toggleXORMode
gerbview.Inspection.showDCodes
gerbview.Inspection.showSource
gerbview.InteractiveSelection
gerbview.InteractiveSelection.Clear
gerbview.InteractiveSelection.SelectItem
gerbview.InteractiveSelection.UnselectItem
kicad.Control.closeProject
kicad.Control.convertImage
kicad.Control.editDrawingSheet
kicad.Control.editFootprints
kicad.Control.editOtherPCB
kicad.Control.editOtherSch
kicad.Control.editPCB
kicad.Control.editSchematic
kicad.Control.editSymbols
kicad.Control.importNonKicadProj
kicad.Control.loadProject
kicad.Control.newFromRepository
kicad.Control.newFromTemplate
kicad.Control.newProject
kicad.Control.openDemoProject
kicad.Control.openProject
kicad.Control.openTextEditor
kicad.Control.pluginContentManager
kicad.Control.showCalculator
kicad.Control.viewDroppedGerbers
kicad.Control.viewGerbers
pcbnew.AlignAndDistribute.alignBottom
pcbnew.AlignAndDistribute.alignCenterX
pcbnew.AlignAndDistribute.alignCenterY
pcbnew.AlignAndDistribute.alignLeft
pcbnew.AlignAndDistribute.alignRight
pcbnew.AlignAndDistribute.alignTop
pcbnew.AlignAndDistribute.distributeHorizontally
pcbnew.AlignAndDistribute.distributeHorizontallyCenters
pcbnew.AlignAndDistribute.distributeHorizontallyGaps
pcbnew.AlignAndDistribute.distributeVertically
pcbnew.AlignAndDistribute.distributeVerticallyCenters
pcbnew.AlignAndDistribute.distributeVerticallyGaps
pcbnew.Array.createArray
pcbnew.Autoplacer.autoplaceOffboard
pcbnew.Autoplacer.autoplaceSelected
pcbnew.Control.DdAppendBoard
pcbnew.Control.ddImportFootprint
pcbnew.Control.flipBoard
pcbnew.Control.graphicOutlines
pcbnew.Control.hideDynamicRatsnest
pcbnew.Control.layerAlphaDec
pcbnew.Control.layerAlphaInc
pcbnew.Control.layerBottom
pcbnew.Control.layerChanged
pcbnew.Control.layerInner1
pcbnew.Control.layerInner10
pcbnew.Control.layerInner11
pcbnew.Control.layerInner12
pcbnew.Control.layerInner13
pcbnew.Control.layerInner14
pcbnew.Control.layerInner15
pcbnew.Control.layerInner16
pcbnew.Control.layerInner17
pcbnew.Control.layerInner18
pcbnew.Control.layerInner19
pcbnew.Control.layerInner2
pcbnew.Control.layerInner20
pcbnew.Control.layerInner21
pcbnew.Control.layerInner22
pcbnew.Control.layerInner23
pcbnew.Control.layerInner24
pcbnew.Control.layerInner25
pcbnew.Control.layerInner26
pcbnew.Control.layerInner27
pcbnew.Control.layerInner28
pcbnew.Control.layerInner29
pcbnew.Control.layerInner3
pcbnew.Control.layerInner30
pcbnew.Control.layerInner4
pcbnew.Control.layerInner5
pcbnew.Control.layerInner6
pcbnew.Control.layerInner7
pcbnew.Control.layerInner8
pcbnew.Control.layerInner9
pcbnew.Control.layerNext
pcbnew.Control.layerPairPresetCycle
pcbnew.Control.layerPrev
pcbnew.Control.layerToggle
pcbnew.Control.layerTop
pcbnew.Control.listNets
pcbnew.Control.localRatsnestTool
pcbnew.Control.netColorMode
pcbnew.Control.padDisplayMode
pcbnew.Control.ratsnestLineMode
pcbnew.Control.ratsnestModeCycle
pcbnew.Control.repairBoard
pcbnew.Control.showLayersManager
pcbnew.Control.showNetInspector
pcbnew.Control.showPadNumbers
pcbnew.Control.showProperties
pcbnew.Control.showPythonConsole
pcbnew.Control.showRatsnest
pcbnew.Control.textOutlines
pcbnew.Control.trackDisplayMode
pcbnew.Control.updateLocalRatsnest
pcbnew.Control.viaDisplayMode
pcbnew.Control.zoneDisplayDisable
pcbnew.Control.zoneDisplayEnable
pcbnew.Control.zoneDisplayOutlines
pcbnew.Control.zoneDisplayTesselation
pcbnew.Control.zoneDisplayToggle
pcbnew.Control.zonesManager
pcbnew.Convert.convertToArc
pcbnew.Convert.convertToKeepout
pcbnew.Convert.convertToLines
pcbnew.Convert.convertToPoly
pcbnew.Convert.convertToTracks
pcbnew.Convert.convertToZone
pcbnew.Convert.outsetItems
pcbnew.DRCTool.runDRC
pcbnew.EditorControl.EditFpInFpEditor
pcbnew.EditorControl.EditLibFpInFpEditor
pcbnew.EditorControl.appendBoard
pcbnew.EditorControl.assignNetclass
pcbnew.EditorControl.boardSetup
pcbnew.EditorControl.clearHighlight
pcbnew.EditorControl.drillOrigin
pcbnew.EditorControl.drillResetOrigin
pcbnew.EditorControl.drillSetOrigin
pcbnew.EditorControl.exportSpecctraDSN
pcbnew.EditorControl.generateBOM
pcbnew.EditorControl.generateD356File
pcbnew.EditorControl.generateDrillFiles
pcbnew.EditorControl.generateGerbers
pcbnew.EditorControl.generateIPC2581File
pcbnew.EditorControl.generateODBPPFile
pcbnew.EditorControl.generatePosFile
pcbnew.EditorControl.generateReportFile
pcbnew.EditorControl.group
pcbnew.EditorControl.groupEnter
pcbnew.EditorControl.groupLeave
pcbnew.EditorControl.hideNet
pcbnew.EditorControl.highlightItem
pcbnew.EditorControl.highlightNet
pcbnew.EditorControl.highlightNetSelection
pcbnew.EditorControl.importNetlist
pcbnew.EditorControl.importSpecctraSession
pcbnew.EditorControl.lock
pcbnew.EditorControl.placeFootprint
pcbnew.EditorControl.removeFromGroup
pcbnew.EditorControl.showEeschema
pcbnew.EditorControl.showNet
pcbnew.EditorControl.toggle45
pcbnew.EditorControl.toggleLastNetHighlight
pcbnew.EditorControl.toggleLock
pcbnew.EditorControl.toggleNetHighlight
pcbnew.EditorControl.trackViaSizeChanged
pcbnew.EditorControl.trackWidthDec
pcbnew.EditorControl.trackWidthInc
pcbnew.EditorControl.ungroup
pcbnew.EditorControl.unlock
pcbnew.EditorControl.viaSizeDec
pcbnew.EditorControl.viaSizeInc
pcbnew.EditorControl.zoneDuplicate
pcbnew.EditorControl.zoneMerge
pcbnew.Generator.genPushEdit
pcbnew.Generator.genRemove
pcbnew.Generator.genRevertEdit
pcbnew.Generator.genStartEdit
pcbnew.Generator.genUpdateEdit
pcbnew.Generator.regenerateAll
pcbnew.Generator.regenerateAllTuning
pcbnew.Generator.regenerateSelected
pcbnew.Generator.showManager
pcbnew.GlobalEdit.changeFootprint
pcbnew.GlobalEdit.changeFootprints
pcbnew.GlobalEdit.cleanupGraphics
pcbnew.GlobalEdit.cleanupTracksAndVias
pcbnew.GlobalEdit.editTeardrops
pcbnew.GlobalEdit.editTextAndGraphics
pcbnew.GlobalEdit.editTracksAndVias
pcbnew.GlobalEdit.globalDeletions
pcbnew.GlobalEdit.removeUnusedPads
pcbnew.GlobalEdit.swapLayers
pcbnew.GlobalEdit.updateFootprint
pcbnew.GlobalEdit.updateFootprints
pcbnew.Groups.groupProperties
pcbnew.Groups.selectNewGroupMember
pcbnew.InspectionTool.DiffFootprint
pcbnew.InspectionTool.InspectClearance
pcbnew.InspectionTool.InspectConstraints
pcbnew.InspectionTool.ShowBoardStatistics
pcbnew.InspectionTool.ShowFootprintAssociations
pcbnew.InteractiveDrawing.alignedDimension
pcbnew.InteractiveDrawing.arc
pcbnew.InteractiveDrawing.arcPosture
pcbnew.InteractiveDrawing.bezier
pcbnew.InteractiveDrawing.centerDimension
pcbnew.InteractiveDrawing.changeDimensionArrows
pcbnew.InteractiveDrawing.circle
pcbnew.InteractiveDrawing.closeOutline
pcbnew.InteractiveDrawing.decWidth
pcbnew.InteractiveDrawing.deleteLastPoint
pcbnew.InteractiveDrawing.drawTable
pcbnew.InteractiveDrawing.graphicPolygon
pcbnew.InteractiveDrawing.incWidth
pcbnew.InteractiveDrawing.leader
pcbnew.InteractiveDrawing.line
pcbnew.InteractiveDrawing.orthogonalDimension
pcbnew.InteractiveDrawing.placeCharacteristics
pcbnew.InteractiveDrawing.placeImage
pcbnew.InteractiveDrawing.placeImportedGraphics
pcbnew.InteractiveDrawing.placeReferenceImage
pcbnew.InteractiveDrawing.placeStackup
pcbnew.InteractiveDrawing.radialDimension
pcbnew.InteractiveDrawing.rectangle
pcbnew.InteractiveDrawing.ruleArea
pcbnew.InteractiveDrawing.setAnchor
pcbnew.InteractiveDrawing.similarZone
pcbnew.InteractiveDrawing.text
pcbnew.InteractiveDrawing.textbox
pcbnew.InteractiveDrawing.via
pcbnew.InteractiveDrawing.zone
pcbnew.InteractiveDrawing.zoneCutout
pcbnew.InteractiveEdit.FindMove
pcbnew.InteractiveEdit.chamferLines
pcbnew.InteractiveEdit.changeTrackWidth
pcbnew.InteractiveEdit.createArray
pcbnew.InteractiveEdit.deleteFull
pcbnew.InteractiveEdit.dogboneCorners
pcbnew.InteractiveEdit.duplicateIncrementPads
pcbnew.InteractiveEdit.extendLines
pcbnew.InteractiveEdit.filletLines
pcbnew.InteractiveEdit.filletTracks
pcbnew.InteractiveEdit.flip
pcbnew.InteractiveEdit.healShapes
pcbnew.InteractiveEdit.intersectPolygons
pcbnew.InteractiveEdit.mergePolygons
pcbnew.InteractiveEdit.mirrorHoriontally
pcbnew.InteractiveEdit.mirrorVertically
pcbnew.InteractiveEdit.moveCorner
pcbnew.InteractiveEdit.moveExact
pcbnew.InteractiveEdit.moveMidpoint
pcbnew.InteractiveEdit.packAndMoveFootprints
pcbnew.InteractiveEdit.properties
pcbnew.InteractiveEdit.rotateCcw
pcbnew.InteractiveEdit.rotateCw
pcbnew.InteractiveEdit.simplifyPolygons
pcbnew.InteractiveEdit.skip
pcbnew.InteractiveEdit.subtractPolygons
pcbnew.InteractiveEdit.swap
pcbnew.InteractiveMove.copyWithReference
pcbnew.InteractiveMove.move
pcbnew.InteractiveMove.moveIndividually
pcbnew.InteractiveMove.moveWithReference
pcbnew.InteractiveRouter.AttemptFinish
pcbnew.InteractiveRouter.Autoroute
pcbnew.InteractiveRouter.BreakTrack
pcbnew.InteractiveRouter.ContinueFromEnd
pcbnew.InteractiveRouter.CustomTrackViaSize
pcbnew.InteractiveRouter.CycleRouterMode
pcbnew.InteractiveRouter.DiffPair
pcbnew.InteractiveRouter.DiffPairDialog
pcbnew.InteractiveRouter.Drag45Degree
pcbnew.InteractiveRouter.DragFreeAngle
pcbnew.InteractiveRouter.EndTrack
pcbnew.InteractiveRouter.HighlightMode
pcbnew.InteractiveRouter.InlineDrag
pcbnew.InteractiveRouter.PlaceBlindVia
pcbnew.InteractiveRouter.PlaceMicroVia
pcbnew.InteractiveRouter.PlaceVia
pcbnew.InteractiveRouter.RouteSelected
pcbnew.InteractiveRouter.RouteSelectedFromEnd
pcbnew.InteractiveRouter.SelLayerAndPlaceBlindVia
pcbnew.InteractiveRouter.SelLayerAndPlaceMicroVia
pcbnew.InteractiveRouter.SelLayerAndPlaceVia
pcbnew.InteractiveRouter.SelectLayerPair
pcbnew.InteractiveRouter.SettingsDialog
pcbnew.InteractiveRouter.ShoveMode
pcbnew.InteractiveRouter.SingleTrack
pcbnew.InteractiveRouter.SwitchPosture
pcbnew.InteractiveRouter.SwitchRounding
pcbnew.InteractiveRouter.UndoLastSegment
pcbnew.InteractiveRouter.WalkaroundMode
pcbnew.InteractiveSelection
pcbnew.InteractiveSelection.Clear
pcbnew.InteractiveSelection.Cursor
pcbnew.InteractiveSelection.DeselectNet
pcbnew.InteractiveSelection.FilterSelection
pcbnew.InteractiveSelection.GrabUnconnected
pcbnew.InteractiveSelection.ReselectItem
pcbnew.InteractiveSelection.SelectConnection
pcbnew.InteractiveSelection.SelectItem
pcbnew.InteractiveSelection.SelectItems
pcbnew.InteractiveSelection.SelectNet
pcbnew.InteractiveSelection.SelectOnSchematic
pcbnew.InteractiveSelection.SelectOnSheet
pcbnew.InteractiveSelection.SelectSameSheet
pcbnew.InteractiveSelection.SelectUnconnected
pcbnew.InteractiveSelection.SelectionMenu
pcbnew.InteractiveSelection.SyncSelection
pcbnew.InteractiveSelection.SyncSelectionWithNets
pcbnew.InteractiveSelection.UnselectItem
pcbnew.InteractiveSelection.UnselectItems
pcbnew.InteractiveSelection.unrouteSelected
pcbnew.LengthTuner.AmplDecrease
pcbnew.LengthTuner.AmplIncrease
pcbnew.LengthTuner.EndTuning
pcbnew.LengthTuner.Settings
pcbnew.LengthTuner.SpacingDecrease
pcbnew.LengthTuner.SpacingIncrease
pcbnew.LengthTuner.StartTuning
pcbnew.LengthTuner.TuneDiffPair
pcbnew.LengthTuner.TuneDiffPairSkew
pcbnew.LengthTuner.TuneSingleTrack
pcbnew.MicrowaveTool.createFunctionShape
pcbnew.MicrowaveTool.createGap
pcbnew.MicrowaveTool.createLine
pcbnew.MicrowaveTool.createStub
pcbnew.MicrowaveTool.createStubArc
pcbnew.ModuleEditor.checkFootprint
pcbnew.ModuleEditor.copyFootprint
pcbnew.ModuleEditor.createFootprint
pcbnew.ModuleEditor.cutFootprint
pcbnew.ModuleEditor.deleteFootprint
pcbnew.ModuleEditor.duplicateFootprint
pcbnew.ModuleEditor.editFootprint
pcbnew.ModuleEditor.exportFootprint
pcbnew.ModuleEditor.footprintProperties
pcbnew.ModuleEditor.hideFootprintTree
pcbnew.ModuleEditor.importFootprint
pcbnew.ModuleEditor.newFootprint
pcbnew.ModuleEditor.openWithTextEditor
pcbnew.ModuleEditor.pasteFootprint
pcbnew.ModuleEditor.renameFootprint
pcbnew.ModuleEditor.repairFootprint
pcbnew.ModuleEditor.showFootprintTree
pcbnew.Multichannel.generatePlacementRuleAreas
pcbnew.Multichannel.repeatLayout
pcbnew.PadTool.ApplyPadSettings
pcbnew.PadTool.CopyPadSettings
pcbnew.PadTool.PushPadSettings
pcbnew.PadTool.defaultPadProperties
pcbnew.PadTool.enumeratePads
pcbnew.PadTool.explodePad
pcbnew.PadTool.placePad
pcbnew.PadTool.recombinePad
pcbnew.Picker.selectItemInteractively
pcbnew.Picker.selectPointInteractively
pcbnew.PointEditor.addCorner
pcbnew.PointEditor.arcKeepCenter
pcbnew.PointEditor.arcKeepEndpoint
pcbnew.PointEditor.chamferCorner
pcbnew.PointEditor.removeCorner
pcbnew.PositionRelative.positionRelative
pcbnew.PositionRelative.positionRelativeInteractively
pcbnew.PositionRelative.selectpositionRelativeItem
pcbnew.ReannotateTool.ShowReannotateDialog
pcbnew.ScriptingTool.pluginsReload
pcbnew.ScriptingTool.pluginsShowFolder
pcbnew.TableEditor.editTable
pcbnew.ZoneFiller.zoneFill
pcbnew.ZoneFiller.zoneFillAll
pcbnew.ZoneFiller.zoneFillDirty
pcbnew.ZoneFiller.zoneUnfill
pcbnew.ZoneFiller.zoneUnfillAll
pcbnew.lengthTuner.AmplDecrease
pcbnew.lengthTuner.AmplIncrease
pcbnew.lengthTuner.SpacingDecrease
pcbnew.lengthTuner.SpacingIncrease
plEditor.EditorControl.LayoutEditMode
plEditor.EditorControl.LayoutNormalMode
plEditor.EditorControl.PreviewSettings
plEditor.EditorControl.ShowInspector
plEditor.InteractiveDrawing.drawLine
plEditor.InteractiveDrawing.drawRectangle
plEditor.InteractiveDrawing.placeImage
plEditor.InteractiveDrawing.placeText
plEditor.InteractiveEdit.appendWorksheet
plEditor.InteractiveMove.move
plEditor.InteractiveSelection
plEditor.InteractiveSelection.AddItemToSel
plEditor.InteractiveSelection.AddItemsToSel
plEditor.InteractiveSelection.ClearSelection
plEditor.InteractiveSelection.RemoveItemFromSel
plEditor.InteractiveSelection.RemoveItemsFromSel
plEditor.InteractiveSelection.SelectionMenu
Fantastic!!!thank you very much!!!what amazing becoming part of this community!!!
