Is it possible to draw ellipses as defined by an X and a Y dimension as opposed to applying radius to both X and Y?
(Note: A pair of combined arcs don’t quite do the trick.)
No, these can’t be represented natively in KiCad at the moment. The best route is to draw them in an external MCAD tool and then import as DXF; they should be converted to bezier splines.
