I am running into this weird issue where the all my tags (global or local) are “not connected”. I have deleted and redone the tags a few times and that does not work. I am not sure what else to do. Grid is set to 1.27mm so it isn’t that part.
Report snippet:
[global_label_dangling]: Global label not connected anywhere else in the schematic
; Severity: warning
@(167.6400 mm, 147.3200 mm): Global Label ‘GAP0’
; Severity: warning
@(110.4900 mm, 146.0500 mm): Global Label ‘FAULT0’
Local labels and global labels with the same name connect with each other on the same sheet, so there is no need for doubling up.
For the rest … I don’t really know. Is this on a single sheet or is it a hierarchical design?
Are there also other less obvious ERC messages that could shine some light on the cause?
One thing you can do is to make a copy of your project and then start deleting parts of the schematic to narrow down the cause.
It is a hierarchical design. I did make a copy and started deleting and nothing changed. I gave up after 1/2 deleting and the error kept coming back. All errors are pretty much related to this (outside of the 1 power in error)
Full ERC below:
***** Sheet /pBitCal/
; Severity: warning
; Severity: warning
[pin_not_driven]: Input pin not driven by any Output pins
; Severity: error
@(119.3800 mm, 146.0500 mm): Symbol U107 Pin 11 [4A, Input, Line]
***** Sheet /errorInject/
[power_pin_not_driven]: Input Power pin not driven by any Output Power pins
; Severity: error
@(72.3900 mm, 128.2700 mm): Symbol U11 Pin 7 [GND, Power input, Line]
***** Sheet /errorDetect/
***** Sheet /errorFixCalc/
[label_dangling]: Label not connected to anything
; Severity: error
@(214.6300 mm, 26.6700 mm): Label ‘GAP0’
; Severity: error
@(171.4500 mm, 85.0900 mm): Label ‘GAP0’
; Severity: warning
@(165.1000 mm, 85.0900 mm): Global Label ‘GAP0’
; Severity: error
@(142.2400 mm, 81.2800 mm): Label ‘FAULT0’
; Severity: warning
@(142.2400 mm, 81.2800 mm): Global Label ‘FAULT0’
***** Sheet /transmitCorrected/
; Severity: error
@(29.2100 mm, 55.8800 mm): Label ‘GAP0’
; Severity: error
@(39.3700 mm, 55.8800 mm): Symbol U11 Pin 3 [1B, Input, Line]
; Severity: error
@(101.6000 mm, 24.1300 mm): Label ‘GAP0’
I’d rather not upload it . I am making a kit to for the youts for the first soldering and programming kit which shows in hardware a Hamming(15,11). Everything is THT and chunky.
What I think is happening is that you can come up a level hierarchical level and connect to a global (tmpGAP0) but not go down a level, then connect to a global (FAULT0 or GAP0). Will investigate and upload later if I can recreate.
