Good afternoon.
Relay coil (part A) on sheet No. 1, contact (part B) on sheet No. 2, contact (part C) on sheet No. 3.
Tell me how to do it: the contact (part B and C) showed that they are the heirs of the coil (part A) on sheet No. 1 and the position of the coil on the sheet (according to the frame). Example K1B sheet_1.4B.
On sheet number 1, the coil (part A) showed that it had heirs on sheets 2 and 3.
For me, it is not really clear what you are asking.
Where is the actual problem or what is the goal you have trouble reaching?
B and C are not heirs of part A. If anything they are siblings.
You just have to use the same reference descriptor for all units of the relay. For example if the relay is RL1, then put the coil RL1A on sheet 1, the contact RL1B on sheet 2, and the other contact RL1C on sheet 3. No need to involve the sheet name. Is this what you want?
Good afternoon.
I wanted to design a circuit like for example qelectrotech.
Not familiar with it.
When drawing up electrical circuits, for example, a relay, near the coil it is indicated on which listas its contacts are used, indicating the position on the sheet (according to the frame). Near the contacts, the sheet on which the coil is located and its position on the sheet are indicated. If interested, I can send pictures.
+1 for the picture. But as I wrote yesterday I think this is currently not possible in kicad.
Sheet-1.pdf (10.9 KB)
