EESCHEMA: [WISHLIST] different grid for symbols and text items
It was discussed here many times that it is not recommended to change default Grid spacing for EESCHEMA, and I generally agree with that.
However, many times I want to change the default Grid just to rearrange Text items (designators, values) on my schematic since the default values are not precise enough to my taste. I like the texts to be placed close enough to symbols that there’s no doubt which symbol these texts belong to (imagine some “busy” areas).
Maybe it would be a good idea to introduce finer grid for Text items, to which the exact placement is not important but they should just be “easy on the eye”. What do you think of that?
FYI, as a workaround you can disable the grid momentarily while moving the text (M) by keeping the Shift and Ctrl keys down. This way, you can place your text items very precisely.
@Efcis I even checked single modifier keys to no avail, didn’t know about the Shift+Ctrl cobo
@MichaelKavanagh Thanks, Thumbed up :slight_smile:
AFAIK disabling grid snapping with Alt only works in Pcbnew.
FYI in Pcbnew, Shift disables snapping to magnetic points.
Edit: whoops, turns out Alt disables grid snapping in Eeschema too… :man_facepalming:
5.99 or 5.1?
Alt does not disable snap-to-grid for my 5.1.6rc
Yeah, sorry, I should have been more clear. Alt disables grid snapping in Eeschema in 5.99 (nightlies).
Someone told me that here more than an year ago. Recently (month or two ago) I have written the same info here. I found I had to look at keyboard to move my hand from M to Ctrl+Shift and back. The solution worth checking is to use right-click to select Move.
