Hi. I am totally new to kicad. When I open sch file, the Eeschema first gave error that “OpenGL is not found going back to software rendering”. When I press the ok button then the eeschema window keeps loading for forever and is not responding. How can I solve this problem. Thanks.
Update: I moved from version 5.0.5 to 5.0.1 and solved the problem. It might be a bug.
Current: Version: 5.1.5
As we are all volunteers always try and use the latest version if possible because we simply can’t offer much help with every version of the software out there and something you are having problems with may have been addressed by an update.
Welcome to the forum.
- Eeschema not responding when opening Schematicac (same problem and a solution is presented)
