Eeschema 6.0.4
When printing to a file, the output path (once navigated) is remembered only until KiCad is closed, and then that path is lost; the next time KiCad is instantiated, the output path reverts to a default.
I don’t mind using the default filename “output.xxx”, but re-navigating to a remote network path/folder, which is a dozen layers down, is laborious IMO.
Is there an alternate workflow I should be using?
