This affects likewise BOTH, the current stock version 5.1.4, and most recent master 5.99 commits as of this writing.
- System is Linux using xubuntu 18.04.3
- kernel after update is 4.15.0-66-generic #75-Ubuntu SMP Tue Oct 1 05:24:09 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
The issue
An attempt to add (A command) a new symbol in any eeschema sheet, whether blank or not, makes the entire KiCad infrastructure hang indefinitely. The only way to close Kicad from within is a click on the little cross. This times out after a while with a system dialog whether to close the application or not. Alternatively a command line âkillall kicadâ will do.
Apart from that. Without adding a symbol with (A) it is still possible to duplicate any already existing symbol followed by an E to change the library reference to obtain a different symbol, footprint etc. Just a workaround the above issue. This of course works only if there is a symbol already present. Anything else from there works as expected.
This problem showed up after a regular OS update on the 19 October 2019. Part of that update were 9 python 3.6 related files as well as 7 python 2.7 related files. List of files updated in their order of occurrence in the log file below.
versions appear to be python 3.6.8
libpython3.6-minimal:amd64
python3-gpg:amd64
libpython3.6-dev:amd64
python3.6-venv:amd64
libpython3.6-stdlib:amd64
libpython3.6:amd64
python3.6:amd64
python3.6-dev:amd64 -
versions appear to be 2.7.15
python2.7-dev:amd64
python2.7-minimal:amd64
libpython2.7:amd64
python2.7:amd64
libpython2.7-dev:amd64
libpython2.7-minimal:amd64
libpython2.7-stdlib:amd64
What raised a big red flag is the fact that the current 5.1.4 stock version is affected by that as well. Yikes.
Any ideas?
Application: KiCad
Version: 5.1.4-e60b266~84~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.15.0-66-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.4.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Application: KiCad
Version: (5.99.0-258-gc6416066b-dirty), release build
wxWidgets 3.0.4
libcurl/7.58.0 GnuTLS/3.5.18 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Build date: Oct 24 2019 11:31:10
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 9.2.1 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
