Hello, I am trying to update my Kicad 5.1.0 to 5.1.5, after deleting the old version and installing the new, opening an old project with .pro is Ok, then when I click to Eeschemas, a window with name as Project Rescue Helper and I have this message : “Could not use OpenGL, failing back to software rendering”
“Cannot link the shaders!” then Eeschema not opening I need to kill the windows.
Do you have an idea ?
Thank you.
Vincent.
Why 5.1.2? The current version is 5.1.5.
I Rene, I was on 5.1.0 then I try 5.1.5, this is a typo ! Sorry.
First I try 5.1.5 then now I’m on 5.1.5-2.
did you read the topic i linked?
Yes, and not sure to understand : “I changed the canvas type in \AppData\Roaming\kicad\eeschema from 1 to 2 and it will now load.”
The file eeschema content only colors …
The file does contain colour definitions but that should really not be all.
The line should be something like canvas_type=2 (2 being opengl, you would want it to be 1).
For reference here my full eeschema file: eeschema (6.6 KB)
What is the path of the eeschema file you looked at? What is your operating system?
Ok thank you René, my file is in: C:\Users\Vincent\AppData\Roaming contains only lines with the same colors as your file (from line 67 to 104), by the way, can I replace my file by yours? Without risk ? Thank you.
So, I renamed my file and copied yours. After that I reload my project, no more error on eschema then 2 warning message on PCB_new but able to see my project. Not sure why the file doesn’t include all the necessary things, but it now seems to work. Thanks again René for your help!
