I’ve a problem running ERC that it gripes about many instances of the short wire connections to GND and other Junctions. Visual inspection shows no miss aligned connection and no square outline of the wire or Gnd symbol end. The wire has not run over the Gnd pin. It looks ok.
I’ve Del the wire and drawn in a new wire. Sometimes this fixes it, other time not.
Del the wire and the Gnd symbol and done a Copy/Paste (short wire and GNd) from another place that does not have a DRC error and the I get aERC error.
I’ve also had an IC with 2 pins tied to separate instances of Gnd. One good, one bad. I fix the bad one, run ERC and then it points the the adjacent previously good Gnd as an error.
I can Drag the Gnd or component and it visually stay connected, but still gives ERC error.
btw - I did read the refernced articles. I interpret the discussion to state that the Pwr_Flag should be added to the +12V as there is no apparent source of +12V (in comes in via the connector).
Not discussed, is that since the LM7805 PRODUCES +5v that there should be No Pwr_Flag on +5v.
Yes, the AMS1117-3.3 (LM7805 huh?) has a pin defined as a “Power output”, and one “Power output” can serve many “Power Inputs”. In fact, you should only have one “Power output” on any net.
There is nothing special aobut a PWR_FLAG. If you look at it’s symbol in the symbol editor you simply see it is just a schematic symbol just like all the others. It has:
1). #FLG = Reference field. the “#” surpresses the symbol from appearing in a netlist, and from getting numbered during annotation.
2). PWR_FLAG = Name of the component.
3). A pin, defined as a “Power output”.
4). A few graphics lines, a diamond with a tail on the bottom.
If you do not like to see PWR_FLAG symbols, you can set the connector pins of the power input connector to pin type “Power output”., but of course that does not work if you have an AC power input and a bridge recitfier, or input filters, or … .
If I get messages about “… not driven by any other pin” and it is a net with a voltage regulator, then I usually set the output pin of the voltage regulator to “Power output” (This may be considered a bug in the library if not set so?). or I add the PWR_FLAG on a spot where it is logical, such as on the last output of a power supply built from discrete components, output of a bridge rectifier, etc.
If that is not enough, It’s time to think about what’s going on and why ERC is (still) complaining.
