hi!
With the two programs opened in two screens, if I select a device/label to be moved in Eeschema the corresponded footprint will be highlighted and centered (if the zoom is big) in PCBnew, but is not happens in reverse (if I select a footprint to be moved in PCBNew nothing happens in Eeschema). I remember for a while ago this was in both directions, there is some preferences to change for this to happen or is a bug from the version?
I’m using version: Application: kicad
Version: no-vcs-found-7518~57~ubuntu16.04.1, release build
Libraries: wxWidgets 3.0.2
libcurl/7.47.0 OpenSSL/1.0.2g zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.4.0-59-generic x86_64, 64 bit, Little endian, wxGTK
- Build Info -
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.58.0
Curl: 7.47.0
KiCad - Compiler: GCC 5.4.0 with C++ ABI 1009
Settings: USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_SCRIPTING_ACTION_MENU=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_SCH_IO_MANAGER=OFF
KICAD_USE_OCE=ON
