Unable to get to Gitlab right now to report a bug.
This is an image snip from the .pdf
Note the +24V in the lower left.This is an image snip of the same area of the schematic file. Note that the +24V is not there. (I had deleted it.)
I also note that symbol disconnect circles are appearing for no apparent reason (indicating that the symbol pins are not connected to the wires.)
19V input car battery charger January 23 2020a.sch (92.6 KB)
My version information
Version: (5.99.0-766-gfe15511d3), release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Build date: Jan 17 2020 22:17:59
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON```
I just refreshed my install to the latest nightly; seems to have resolved this issue. Usually when I install the lite nightly I skip the libraries. But this time it seemed to eliminate my previous libraries when I skipped that. So I tried the install 3 times; including the libraries on the 3rd attempt.
```Application: KiCad
Version: (5.99.0-788-g8f778b5a0), release build
wxWidgets 3.0.4
Build date: Jan 23 2020 07:35:52
Boost: 1.71.0
Curl: 7.66.0
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON```
