Hello everyone, the answer may exist in the forum or RTFM, but sorry I did not find!
So here, in Eeschema how do you make a diagonal wire connection, like for a bus? By default it is horizontal or vertical connections. Thank you !
If well understood the question - I use “Place wire to bus entry” tool from right toolbar.
Hi Piotr, eelik provide me the solution (Thanks !) in fact I’d like to distinguish 2 physicals wires (not PCB layout) on schematic to figure out for example a relay like this :
that’s receive 2 wires on each outside contact. By using standard wiring in Eeschemas this seems like this :
So by not selecting H/V wiring :
Many thanks to ALL !!
