Is there a plugin for editing the coordinates of a zone directly? I know that you can remove or insert corners (square indices) but I would like to be able to edit directly the coordinates without having to do it with a text editor which is unnecessarily cumbersome.
Perhaps this is a feature for the 6.0 build and is in 5.99? I am using 5.1.10
Depending on why you want to do this, you could also set the grid to the same size as the point is where you want to move a corner. This way you are sure you moved it to the correct location.
It is made for adding teardrops to the PCB, but according to it’s description it uses zones to create those teardrops from Python, and you could use it as a basis for modifications.
We have made some desings with difficult zones. We wanted a 6 decimal coordinate while the smallest grid is 0.001mm. Just for aesthetic reasons that nobody but ourselves will ever notice. No, we are not counting electrons But if we wanted a 0.25 gap why stay with 0.250222 gap?
Editing corners would have been great. But I did not rise a bug (a wish) because I thought developers have better aims to improve the tool.
