I was previously running KiCAD on Mint and have re-installed on Ubuntu. Unless I’m going crazy on Mint I could have sworn when I placed a new symbol and edited it only the ? was highlighted so you could just type the reference number like 100.
I’m now finding on Ubuntu that C? is highlighted so I either have to type C100 or move the cursor and type 100. Its something small but annoying. Is this a setting somewhere or am I dreaming and its always worked like this.
Actually just found if I edit the component, the C? is highlighted, then I move the “Edit Reference Field” dialog box slightly it then changes to only the ? being highlighted.
I"m having this issue on 2 PC’s, both Ubuntu.
Application: kicad
Version: 5.1.2-f72e74a~84~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.18.0-24-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.3.0 with C++ ABI 1011
