The file names below the blocks are too close to the blocks and does not print out well Same thing with the Sheet labels at the top of the blocks. Very poor quality prints result.
Need put some space between them. How to do that?
Probably need to change some KiCAD source code to make that happen if I were to guess - as there is no option for it in the program.
Might want to talk to the developers over on:
https://lists.launchpad.net/kicad-developers/date.html
and ask how you can achieve that (which will require you do to do the work or find someone to do it).
