I am trying to create a plugin to create a PCB, I managed to draw in the layers, however, I cannot figure out how to do it in the Edge Cuts. I am using KiCAD 7.0 so maybe that’s the reason. I have tried to look into the pcbnew documentation but I couldn’t find any examples.
This is the code I have right now:
# create the edge cuts
for edge_cut in coil["edgeCuts"]:
edge = pcbnew.PCB_SHAPE(board)
edge.SetShape(pcbnew.SHAPE_T_POLY)
edge.SetFilled(False)
edge.SetLayer(pcbnew.Edge_Cuts)
edge.SetWidth(int(0.1 * pcbnew.FromMM(1)))
v = []
for point in edge_cut:
x = int(point["x"]) + CENTER_X
y = int(point["y"]) + CENTER_Y
v.append(pcbnew.VECTOR2I(x, y))
edge.SetPolyPoints(v)
board.Add(edge)
It doesn’t give any error, however nothing appears in the Edge Cuts layer in KiCAD.
I have tried this too:
edge = pcbnew.DRAWSEGMENT(board)
edge.SetShape(pcbnew.S_SEGMENT)
v = []
v.append(pcbnew.wxPoint(x, y))
edge.SetStart(v[0])
for point in v[1:]:
edge.SetEnd(point)
board.Add(edge)
edge.SetStart(point)
edge.SetEnd(v[0]) # close the polygon
board.Add(edge)
And same issue, no errors but nothing appears in KiCAD.
