Hi all,
I’m having “edge cut” related errors when i place a connector on (or near) the edge of the PCB.
As a quick test, here’s a basic 2 connector setup (pin to pin) between 2x 10pin connectors.
When the right-angle connector (J2) is placed inside the edge boundary, everything is perfect. (see pics).
When the right-angle connector (J2) is positioned at the edge of the PCB (which is my intended position), there are edge-cut errors (see pics).
What do i need to do to get around these errors?
I know i can can simply un-check the “warnings” box in the DRC check (assuming the warnings are ONLY about the edge boundary).
I realise the courtyard boundary of the (J2) connector is extending over the edge-cut line, so is there something i need to add, to extend the edge-cut boundary to accept the J2 connector at the very edge of the PCB?
Also, will i have trouble with PCB manufacturers rejecting my board due to the boundary errors?
Thanks in advance for your advice.
