Easiest way to get a pdf of paste layer
I would like to get a pdf of the paste layer of my PCB so I can use in a laser cutter to make a stencil. What is the easiest way to do this in Kicad?
thanks
Use the built in print function, choose print into file and only select the paste layer.
Wow, well that is certainly easy and appears to work great. Thank you!
Use Plot, not print. Plot is more precise.
