New to Kicad (Eagle deserter), running 4.05
I made a complex board outline in Onshape and then exported the sketch to dxf. When I try to import the dxf into the PCB editor, it seems to work with the exception of making all the line widths 2.54 mm (very thick). It is a real time burner to select each line segment and edit the width, am I missing an obvious way to control imported line thickness?
I have no problem importing Onshape dxf into footprint editor, all lines are expected thickness.
