I tried it with and without the fix discontinuities option and it doesn’t work either way.
I created the edge cut file based on a dxf of my components that I exported from Kicad. This has worked for me before. But I must be doing something wrong now because I completely remade the edge cut DXF and the error still occurs. I also tried two different CAD DXF exports (fusion and draftsight).
From the error message, it doesn’t seem to be complaining about the contour but the size, it even let you know the maximum possible scale, try importing again using 0.5 instead of 1.0 as scale an check the results
Use the Help>About Kicad>Copy Info button and paste your Kicad information here, also if you want share your DXF, in this way someone could test in their system.
Thanks for your help. I dug into this some more and the dxf that were working for me were created in inches. So I plotted another dxf from Kicad in inches this time, and remade the edge cuts again. Now this inches based DXF worked and imported fine.
Not sure why this would be especially considering I’m working in Kicad in mm like the dxf that weren’t working.
I’m using the stable release Kicad 9.0.1 for reference.
I use DXF import pretty frequently in mm without problems, if you will like to give it a try I am attaching a DXF file created by me in FreeCAD to see how it behaves in your system. However I am using a test build of what would be v9.0.2, see information below.
Your file imported for me perfectly. Here is my kicad info.
The file I exported from Fusion that didn’t work was imported to fusion from Draftsight. So maybe the problem is with Draftsight? Draftsight is where I made all the dxf files in both mm and inches.
