That helped thanks. But i am getting a different error.
ErrType(3): Pin connected to some others pins but no pin to drive it
@ (246.38 mm,74.93 mm): Pin 1 (Power input) of component #PWR09 is not driven (Net 1).
Pins with the Electrical type “Power Input” need to be connected to a pin with the Electrical type “Power Output”. In the case where power is supplied from a connector (and almost always the case for GND) you need to add a “Power Flag” to indicate that the net is connected to a power source.
So you need to add a Power Flag to your GND net, preferably at the connector that supplies power to your board.
Vdd pins are already connected via the 3.3V power symbol to Vo of LM117. The same for GND and VSS. The power symbols work as a global labels throughout the schematic.
I recommend you the kicad manual. You can also google for some tutorials.
The power flag that you have on the + terminal of the battery should instead be on the - terminal. Although the pins on the battery itself should be of Power Output type.
Only use power flags where you know you need them, otherwise they just hide errors. The power flag on pin 8 of the DWM1000 module might satisfy ERC but it is not needed and only hides the actual error, there is no connection between the GND net and the power supply.
