I’m using Version 7 - I need to know if there’s any plugin, script or base functionality to either place or duplicate components on a PCB along a path, just as the Fusion 360 feature allows you to click a DXF line to choose that as your path to then duplicate the chosen ‘body’ aka component from your project.
If your graphic program can distribute objects along a curve, then you can let it distribute some kind of placeholders, and then use those as reference points for manual placement.
Next step is to figure out a python script to recognize those placeholders, and let it put the footprint in the right location and orientation. This can probably be done with half a page of python, but it may take a day or two to figure out how to do it.
Well at least you have a semi easy starting point. The problem is that for most people their first need is slightly further than what can be done on your first script. Therefore its best to start before you have your first problem.
Hopefully you know how to deal with affine transformations.
FYI - may be of interest to those not using F360. Plotting nodes along a path using Inkscape
Be sure to click the blue ‘Attachments’ icon in last post to see the detailed steps to doing it…
Then, as paulvdh suggested, in Kicad (after importing) place desired items on the nodes
UPDATE: Added Video
If User’s have a basic familiarity with FreeCAD and it’s KiCadStepUp Workbench to Load PCB, Parts and Pads/Tracks, then making a Path with selected items is very easy.
Video shows doing it, although, to reduce file-size for posting, I did pre-load the PCB and created a Bspline path (Bspline because it can be the most difficult path to follow).
The order of Selection is perhaps the Most Important aspect for FreeCAD (video shows what happens if not correctly selected, then with correct order of selection).
Not shown is the full window with tweak of number of items… And, there are Alignment/orientation… tools if needed… The Path-Array uses the Draft-Workbench.
Thanks for you reply, I completely missed it. This looks promising and interesting!
From what I can see here (and correct me if I’m wrong), you’re essentially plotting/doing what I did on F360 but the footprint itself isnt duplicated nor the nets?
