Hello, I can’t seem to figure out why my pcb file is showing a component with the plated throughholes as per usual but my drill file doesn’t show any holes to be drilled. It was also copied from U1 to create U2,U3 and U4 except only U2 is not creating a proper drill file.
Can we be sure that you have the same footprint for U1, U2, U3? You told us nothing about it.
Have you generated drill files containing PTH and NPTH in one file or in separate files? You also told us nothing about it.
If in separate files than may be your U2 holes are in the second file. May be someone designed for him a footprint with NPTH holes and you used it for U2. At 3D screenshot I can’t see if U2 has plated holes or not.
I think you should write such information in first post to limit the possibilities that should be considered.
Well i’m not sure what changed but maybe I wasn’t updating the drill file or I changed a drill file setting?
What I sent to the fab is the attached and noticed there is a .drl file inside. But when I just tried to generate it again my drill files were named as .gbr on the end. So I’m not sure what changed but it looks like its working now.
