Hi, I am laying out a PCB with silkscreen only on the front of the board.
However I am getting DRC errors saying that there is an overlap between the solder mask and silk screen for components on the rear of the board.
I can clear the errors but it means changing my board setup to have a rear silkscreen, moving the offending items then removing the rear silkscreen from the board setup again.
I would rather that warnings were not generated about a layer which does not appear on my board.
I am using Version 8.0.5
Thanks Peter
(Can I just add that I LOVE KiCAD. it is a very capable and easy to use bit of software. Well done to the developers)
