When running DRC in KiCAD 7.0.6 PCB Editor, I get the following warning for every text object that uses any TrueType font:
[text_thickness]: Text thickness out of range (TrueType font characters with insufficient stroke weight)
Observations:
- Manipulating File->Board Setup…->Design Rules->Constraints->Silkscreen->Minimum text thickness parameter does not help at all, in fact even if I set it all the way to zero, the warning still shows up during DRC.
- For some TrueType fonts the problem disappears if I increase the width and height of the characters from 1 mm to 2 mm, for some other fonts it never disappears.
- The problem does not happen with Arial font (which is also TrueType) at width and height of 1 mm
- The problem never happens with stock KiCAD font.
- It happens to text objects that are both standalone as well as those that are part of the footprints.
- Running DRC in Footprint Editor on identical text objects does not yield a warning
So what I don’t understand is why reducing constraint (as per item 1 above) does not resolve the problem at width and height of 1 mm. Am I doing something wrong or should I file a bug report?
P.S. An no, using stock KiCAD font is not a valid solution - I must use Cascadia Code because it visually distinguishes between zeros and letter O and because it is monospaced.
