Is it possible to use DRC rules to check whether a footprint has a pad that can (must) connect to the current track being routed?
I’d like to match this to construct a (better) neckdown / fanout rule where a controlled-impedance track will be allowed a smaller clearance within the courtyard of a (BGA) footprint.
Edit: Example DRC rule, note that hasNetName()
is the missing bit:
(rule DP_fanout
(condition "(A.inDiffPair('*')
|| A.NetClass == 'DP*'
|| A.NetClass == 'CPHY'
&& B.Type == 'Footprint'
&& B.hasNetName(A.NetName) # How to do this?
&& A.intersectsBackCourtyard(B)"
(constraint clearance (min 0.09mm))
(constraint track_width (min 0.09mm))
(constraint track_width (opt 0.09mm))
