DRC returning error for disconnected Vcc (that's connected..)
I’m having an issue where I can’t remove an error from the DRC. It says the pad is disconnected but shows it obviously is with the thermal reliefs of the filled zone. It’s showing a rats nest trace that goes over tracks to another area as if where it is isn’t connected to the Vcc zone I have created. If I put a via down and draw a track then take it over it resolves the issue with the DRC. Does anybody know why this could be and how I could rectify the issue without using a via.
Thanks
You haven’t shown if the lower left Vcc zone connects to the rest of the Vcc zone . . . I suspect not.
Well this is embarrassing…
