I have a part (SMSC LAN9500A) which takes a 3.3V input and outputs a distinct supply from an internal regulator on two pins, 50 and 21. I’ve created a part for it, giving these two pins the same name and marking them as power outputs. However, when I try to connect them both to the same net, I get a DRC error about conflict between two power outputs. In a sense it’s right, but the circuit is also correct.
There is nothing wrong with having an ERC error WHEN you understand why.
As you have just found out, these corner cases are hard to fix with simple checking logic
Usually Pcbnew DRC errors are more serious and should be corrected
